idle issues
madteggy
I have an ls/v obd2 integra it was idling between 2k to 3k when i started it and the same while it was warm i looked through sum posts n did the adjustment of the screw with the car warm and iacv dis connected so i was able to drop it to 1 1/2 k nd i dont have a fitv and im running a odb2 p72 ecu have no cell codes on dash can ne one help with issue
hold your hand over the throttle body so no air gets it. if it dies then it should be the iacv, if it doesnt then you have a leak somewhere.
I TRIED COVERING THE im AND I DID HAVE A LEAK IT WAS COMING FROM A SMALL HOSE PORT ON BACK OF im SO WASNT SURE WERE IT WENT SO I SEALD IT W HOSE N SCRW MY IDLE STILL THE SAME NOW I COVER MY im N MY ENGINE DIES CAN NE ONE HELP
