The fact that its making a "sucking sound" makes me think that the throttle adjust screw is loose, or improperly adjusted. As you unscrew it you get a distinct "sucking" noise becuase air is being pulled through such a small space and the car starts having really wierd problems. I bet it's screwing up your vacuum and your idling wierd becuase the computer is getting wrong readings.
I don't know exactly whats its supposed to be called, but it's the big screw thats on the throttle body. On my car it's brass colored and on the top left of the throttle plate.
It has a back stop, you can't screw it in too far, and its made to be all the way in on a properly adjusted engine, comes that way from the factory and they say don't 'screw' with it... Sorry bad joke.
HTH
Buzz1167
Jon N
