jrhitman6998
ok i amm having a problem with my integra it has a b20 in it and it will not idle right and at times it will idle fine and then while i drive it at lights and stuff the idle will act up also the car has a misfire i believe if i pull out the spark wires from 2,3,4 then idle decreases but it feels like the idle increases when i pull out the wire from 1. also listen to the car when i hold the throttle a lil open thanks and sorry for the bad quality i can try and get another vid if needed.
