Idle problem
97CIVSI
What's up guys im idleing pretty rough between 1000 and 1500 rpm when it holds and idle its at like 500 to 600... I need to know where the idle pressure switch is... I think that's what's its called anyhow.. its on a D16Z6... thanks alot
IACV..
mounted on the intake,on the firewall side.
There is a 2 wire plug and 2 smaller coolant hoses attached.
Pull it off, (2) 12mm hex head nuts> clean w carb cleaner and air it out w high pressure.
