hondadelsolsi16
i have a 93 delsol swaped a 99b16a2 obd2 motor in it.ok,friend changed eveything
to obd1 and said it would work.useing gsr p72 ecu,ls dist,and the del sol wiring harness single-vtec. the motor starts and when the motor lets it self rev high enough the v-tech does pop over..heres the problem when i start it the idel is stedy at 700rpm a few seconds later it keeps jumping 700-1100rpm.it does not want to idel right the air to fuel gauge reads rich and once in a while lean,but manly rich.it will rev but then cut me off at 5000rpm most of the time.what could be the problem???
