haao13
Member
so i put a d16z6 in my 93 hatch and now when im sitting at a red light it idles fine at around 800 rpm but then it will drop down to around 500 and feels like its gonna stall. it does this until i start going again. when i did the swap my map sensor was on the fw and had a vacuum line running from it to the tb, but there isnt a spot for the vacuum line on the z6. and im using the map on the tb of the z6. idk it that is the problem or not. any info would be great. thanks
