natecspecr
Member
hi sir,
Actually my normal idling rpm are quit ok but is a bit weird when i rev the rpm and release the pedal then the rpm while suddenly drop until 100-200rpm like going to die off after a while it will going up to 700rpm ? but for normal case the rpm while stop at 1200rpm the slowly drop down to 800-900rpm right ? need your help on this matter , ecu no throwing any faulty code sensor all ok , tps reading set to 0.5v . Thank you .
