idling problem
Discussion in 'HYBRID -> EG-EK / DC' started by Banshee350, Oct 13, 2008.
  1. Banshee350
    Banshee350 New Member
    I got a 96 civic lx. i parked her for a year then when i got er on the go again, after she warms up and goes into low idle her idling goes up and down over and over again. engine light is on and obd 2 says the o2 sensor heater is bad. p 0141. but i don't think that makes any difference to her idling.. so i'm not sure what to check. any ideas?
  2. Banshee350
    i checked the filters, fuel pressure, plugs and wires, can't find any vac leaks, the injectors fires kinda quick untill she revs up high, then cut out untill shes goes pretty low then start firing again till shes high.
  3. 4U2H8ME
    4U2H8ME Beer its whats for dinner
    BRONX, NY
    I've seen this happen alot on hondas put into storage. 1st. try taking it on a nice long drive, the coolant sometimes gunks up in the idle valve and may free up after a nice long drive, if not the #2 replace idle valve and coolant.
  4. Banshee350
    yea i took her for a nice long drive probably like 1500 kms in all in hopes that she would clear up. i never bleed the cooolant system though, i guess she might be air locked in the idle valve. probably wouldn't hurt to clean it and bleed the system. is the idle vlave under the throttle body?
  5. 4U2H8ME
    BRONX, NY
    Not sure on the civic, try looking for a bleeder on the thermostat housing, but definately bleed this system, air trapped in the idle valve will cause an irradic idle.
  6. Banshee350
    Right on, i'll give that a try, thanks
  7. 4U2H8ME
    BRONX, NY
    Bleed Cooling System
    Without Bleed Bolt
    The late ’95 and ’96 Civics have no cooling system
    bleed bolt on the thermostat housing like past models.
    When refilling the cooling system, use this procedure to
    remove trapped air:
    1. Fill the coolant reservoir to the “MAX” mark.
    2. With the temperature control lever in the “hot”
    position, fill the radiator to the base of the filler
    neck, and loosely install the radiator cap.
    3. Start the engine, and let it run until the radiator fan
    comes on at least twice.
    4. Stop the engine, remove the radiator cap, and refill
    the radiator to the base of the filler neck.
    5. Install the radiator cap tightly.
    Here's an article from Honda that should help you bleed your system.
    If you Feelin the info, Rep me up!!!!!
