If I was to have done it...
astroboy
I bought a 90 dx HB with a mini me (which has been swapped out for a d16z6). The car has a rywire adapter to hook up the p28. I am not sure how much was done correctly so I want to give the entire car a once over and make sure it was done correctly (there are a few questionable wire nut's happening under the hood). Soooooo what should have/would have been changed to make the engine (and cluster) run properly. Only power mods are i/h/e and the vtec is not hooked up. Any links/wiring diagrams/"search this:..." are welcome!
After looking at some more things I think I need to provide a scosie more info: car also has the 4 wire o2 sensor wired to the p28, d16z6 distributer (which has 2 wires cut and one from the other side of the harness spliced in), and either a ex/si harness under the hood with resistor box or a modified dx harness. Is there a way to tell what it is under the hood?
Ok, gotta wait till I get home to see if I have two cannon plugs or three on the passenger side inner fender well when I get home...but I think it is two which would make it a converted dx harness, correct? Or could it be a zc? I don't think it could be but...
