ignition control module
Discussion in 'ECU's, Electronics, and Tuning' started by typesiracing, May 14, 2004.
  1. typesiracing
    typesiracing Senior Member
    ny
    i had a no start condion on a swap i just finished....it started a couple times and sounded good....but then i shorted something out and think i fried something....i checked all the fuses because the car was cranking, i could smell the fuel but i was getting no spark and they were all good....anyway....i changed the internal coil....didn't work....so i tried to use an icm out of a sohc prelude distributer and nothing either? just wondering if anyone knows whether they are compatible or any other ideas to solve this issue....thanks
  2. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    ICMs are pretty interchangeable.
    I use 5G Civic ICMs in my 4G Civic.
    you should be fine.
  3. typesiracing
    ny
    any ideas of what my problem could be then? thanks dave
