Ignition problem
Discussion in 'General Tech and Maintenance' started by b16coupe, Mar 1, 2005.
  1. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    On the way home today, my car just shuts off. No warning signs at all.
    As i was coasting, i put it in 2nd gear and let the clutch out. The rpm raised to like 4500 but the car still wouldn't start. So i get to a parking lot and try to start and all it does is turn over. I reached over and unplugged the ecu for about a minute then plugged it back in. Nothing.....just turned over. I can hear the main relay and fuel pump. I put a timing light on hte no.1 sparkplug wire and the light didnt come on when tring to start the engine. This is where i need your help. How do i check the distributor to make sure it is ok. I just replaced it about 1 month ago.
    I have access to a multimeter.
    Thanks in advance
    James Hamer
  2. formby
    formby learning in progress
    sounds like the coil is over heating......does it turn on after it sits for a while?
  3. b16coupe
    anderson, S.C.
    OMG!!!!!!!!!!!!!! I am an idiot. I placed my blow off valve in a bad spot and it knocked one of the distributor plugs out of its socket. I am waiting on my flange so i can put my new greddy type s in the right spot.
    Thanks for the reply though
