ignition problems
Discussion in 'ECU's, Electronics, and Tuning' started by ^crx^, May 20, 2005.
  1. ^crx^
    ^crx^ Senior Member
    my car wont start. but i do get a little spark on all plugs so i going to change coil and igniter.
    but can i just buy an external MSD coil and bypass the broken internal coil?
    where can i find a low priced igniter for a TD44U & TD68U Integra GSR / 92-95 JDM B16A
  2. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    you could always just replace the dizzy, check you local junk yards / ebay / honda-tech / here/ homemadeturbo.com
  3. pissedoffsol
    ignitors run about 75 bucks from autozone.
    obd0 distribuitors are known for eating ignitors...
    external coils EAT ignitors... they are way too strong for it IMO. you'll be replacing them once a month... i'd just run a stock one.
  4. ^crx^
    ^crx^ Senior Member
    what? once a month? thats sounds werry strange. but as i understad is it that the external coil dont have same resistance (ohm). what about putting an aditional resistance to out balance the voltage??
  5. pissedoffsol
    its pointless anyway. unless yo're revving to 10,500, there is no need to alter the oem ignition signal.
  6. ^crx^
    ^crx^ Senior Member
    okay. well i was thinking if an external coil fries the oem ignitor, why not reduce the voltage from the coil to the ignitor?
