ignition probs crx
Discussion in 'ECU's, Electronics, and Tuning' started by 2fastteg, Apr 30, 2005.
  1. 2fastteg
    2fastteg Member
    ihave a 89 crx dx or hf i dont know but is it possible to run a wire just to a toggle switch to get power and use a push button to start with my entire ign wires are fuked over i just want to know if i can run a wire or something to the switch sothis bitch will run again
  2. allbottledup
    allbottledup Senior Member
    Galloway, NJ
    I did that in my old hatch. Got rid of the key completely. I has two toggle switches and a push button. One switch was the ACC, One was ON, and the push button was start. I hacked the wires going to the key and ran them to the switches. Each switch need power then send the wires for the 3 above to each switch.
  3. allbottledup
    Galloway, NJ
    Wiring diagram
    Thats the link for the diagram for the ignition switch this is how I did it on...if you need more help let me know Ill give you my Phone # might be easier to explain
  4. 2fastteg
    2fastteg Member
