flydex28
So Ive got some electrical issues again. This time I was leaving work the other night and as I was pulling out onto the highway to head home the car just kind of sputtered and then died. Will not start at all. I suspected the coil but when I did that simple test to check ohms I got .8 ohms and the 11.54k ohms on the second test which seems to be within spec. I checked the timing belt and it seems ok. The plugs get wet with fuel but not getting any spark. I heard you have to have special equipment to check the ignitor. I do have my old engine (d15b8) and it looks like the coil is the same part number but im not sure about the ignitor. Hopefully its still at my dads shop. My current engine is the B16A SiR2. Can anyone give me any insight. That old engine of mine is 50 miles away...meaning like $30 or $40 in gas just to go get it in my other rig.
