I'm an idiot and I need help with my husbands car
Discussion in 'ECU's, Electronics, and Tuning' started by HSHoochie, Aug 2, 2009.
  1. HSHoochie
    HSHoochie Junior Member
    Bristol, CT
    My husband has a 1990 Civic si and is in need of replacing the "Electronic Load Detention module"??? I called Napa and they have never heard of this. I found a somewhat part # (A-8460) but I cannot find it anywhere. Does anyone know where I can get a replacement part? Or even where it is located in the car? He originally thought he needed an alternator, but alas, he does not.
    Yes, I realize my name is Hoochie. LOL
  2. FREEBYRD1962
    FREEBYRD1962 New Member
    Whats the problem wit da car
  3. HSHoochie
    Bristol, CT
    It starts but if you disconnect the battery it dies. It's only running at about 12.5 volts. It's supposed to be 14. The battery light is on, if you start the car and disconnect the alternator the battery light goes off and the car still runs.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it should be in the fuse box under the hood
  5. HSHoochie
    Bristol, CT
    and of course B is sleeping and I can't get a hold of E solsi
  6. nootrac22
    exeter pa
    figures, but E is prolly out killing zombie strippers anyway.
  7. AHHVTEC
    Alabama
    sounds like a bad alternator to me.
  8. HSHoochie
    Bristol, CT
    That's what I said so he went to get one and it says this on the parts sheet,
    "Reman; 60 Amps; INSTALLATION ALLERT! This application uses an "Electronic Load Detector" in conjunction with the Electronic "something (can't read the sheet is cut off)" regulate alternator output. Follow prescribed test procedure for a "no charge" condition.; See Tech Tip #626
    Then I did some research online and saw this,
    "Honda/Acura models built after 1988 may experience rough idle, stalling or low/no altnernator output. This has been traced to failure of the ELD (electronic load detention) module. This module is designed to improve fuel economy by almost shutting the alternator off during light throttle and idle. If this module malfunctions, the ECM losses a sensor and the above listed symptoms appear. A code 20 may also be set." Then it has part No. A-8640
    WTF???
  9. HSHoochie
    Bristol, CT
    probably
  10. AHHVTEC
    Alabama
    well you can always take the alternator to autozone ect ect, and they can put it on a bench tester to see if its good or not
  11. nootrac22
    exeter pa
    there is a zombie stripper thread here. It's legit the DOT warning sign even notified motorists
  12. HSHoochie
    Bristol, CT
    I could try that. He doesn't get out of work until 4.
    It sucks because the car is awesome. Totally stock. One owner. It only has 37K original miles!
  13. HSHoochie
    Bristol, CT
    seriously???
  14. phyregod
    phyregod !!YTINASNI
    Central Texas
    With charging problems. What a piece of junk. You should sell it to me!!!:ph34r:
    Ok, ok...
  15. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I had the CEL in my 88 Civic; replaced the fusebox...it went away. :)
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i think i might have the fusebox if it helps..
  17. Briansol
  18. rfrumusa01
    rfrumusa01 Bean Cakes
    Rochester, NY
    Don't waste your time testing it. 9 times out of 10 it is a blown fuse under the dash... the "alt" fuse under the dash is likely blown. Test all of them to be sure. If thats not the problem, the fuse box under the hood will need to be replaced. However, i don't recall a EF having an ELD, I would double check that. Does this vehicle have an OBD-I swap or ECU conversion?
  19. K2e2vin
    Raleigh, NC
    CRX does have a ELD. I know this because I had the same CEL and fixed it by swapping fusebox(I had to swap all of my fuses too in case you were wondering; bought the fusebox "barebone") That picture Phyregod posted up is from a CRX.
