im confused
Discussion in 'HYBRID -> EG-EK / DC' started by BIGMAN, Mar 22, 2004.
  1. BIGMAN
    BIGMAN Senior Member
    U.K
    i spoke to a guy at a tuning company and he said that he wouldnt be able to chip my old civic ecu to run my b18c engine he reckoned it werent just a case of chipping it cos of the engine size difference,yet you guys reckon i can.my brain hurts..
    also i got a two pin plug on the engine wiring harness at the back comming up from behind the fuel injection system that ive got no where to plug into on the engine or engine bay its got a red/yellow and yellow/black wire. anybody got any ideas :blink:
  2. pissedoffsol
    you've got to be more specific about what you have.
    car year, model, trim
    wire harness used
    obd/year of motor
    obd result
    and [off topic] but who the hell still says 'reckon'? lol
  3. BIGMAN
    U.K
    my cars an eg civic 1.5 with an obd 1 harness the new engines obd2 b18c out of a type r. wot you reckon lol
  4. pissedoffsol
    you didn't answer my questions....
  5. BIGMAN
    U.K
    my cars a honda civic coupe 1.5. the wiring harness in it is obd 1.
    the engine i put in it is a 1999 integra type r which is obd 2 which i have an obd 2 ecu to go with it
  6. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    people like him still say reckon.
    reck·on
    v. reck·oned, reck·on·ing, reck·ons
    v. tr.
    -To count or compute: reckon the cost. See Synonyms at calculate.
    -To consider as being; regard as. See Synonyms at consider.
    -Informal To think or assume.
    v. intr.
    -To make a calculation; figure.
    -To rely with confident expectancy. See Synonyms at rely.
  7. pissedoffsol
    for the 3rd time now...
    there's at least 32 obd1 harnesses. WHICH ONE
  8. BIGMAN
    U.K
    shit.......... sorry to mess you about didnt realise there were that many different harnesses any ideas how to find out
  9. E_SolSi
    ok i will attempt to spell this out in very easy to understand terms
    i will use myself for an example
    1993 , del sol , Si
    wire harness used
    93 del sol Si harness modified to fit OBD-2 plugs (injectors and distributor)
    obd/year of motor
    OBD-2 / 2000+ JDM ITR (B18C)
    obd result
    im using a chipped OBD-1 P28 so my setup is OBD-1
    so.....
    car year, model, trim = what the hell car are you starting out with (what is the engine swap going in?)
    wire harness used = what harness are you using???
    obd/year of motor = i dont know how to make this any clearer
    obd result = what ECU are you running it with
  10. BIGMAN
    U.K
    car year,model ,trim
    1995 , civic , dx
    wiring harness used
    95 civic harness obd1 with added vtec wires running to the ecu and obd2 engine harness that came with the motor and plugged straight in to the original harness
    obd , year of motor
    obd2 , 1999 jdm integra type r
    obd result
    i have an obd 2 integra ecu that doesnt plug in (shall i just get a conversion harness)
    i have an obd 1 civic ecu that plugs in but wont run the engine (can i get this ecu to run my engine if i have it chipped cos the guy at the tuning company said it wasnt just a case of getting it chipped so no)
  11. E_SolSi
    ok run a chipped P28 or P30 (P28 will be cheaper and easier to find)
    and get something to tune with (VAFC, Hondata, etc)
    the DX ECU can not control VTEC (chipped or not)
  12. BIGMAN
    U.K
    thanks guys sorry it took so long to get there relly appreciate it :D
  13. pissedoffsol
    :p its just impossible to answer a question correctly when we don't know what your'e dealing with
