i just put a b16a1 out of a 91 civic sir into my 94 ex and it won't run? changed the harness, distributor, header, msd sci ignition, remote coil, 68mm throttle body, beru plugs, nology wires, skunk2 chipped and programmed p28 ecu, venom injectors made for the 94 ex, i've don it all and still can't get the car to run. it has spark, fuel, air, timing is good and so is the compression. i'm losing it, what the hell can i do?????
