Im planning to do a B16A OBD2 swap on a 97 Civic EK hatch.
The donor engine is from a 99-00 Civic SI.
I've got everything but the ECU and harness.
I've heard that on the P2T ECU from the 99-00 SI has some kind of immobilizer device so that you cant start your car without the special key.
So my question is if I should buy the P2T ECU or not. If I do then... how about the immobilizer issue....how could I bypass that. Pleassssssssssseeeeeee Help.....
PS any advice would be greatly appreciated!
