imobilizer problems
GSRcivic2000
hey, i live in ohio and i have a 2000 civic with a 2000 gsr b18c1 swap, unfortunetly, ohio has an echeck, and to get my car to start the imobilzer out of the ecu (from the same gsr as the motor) was removed, the problem, it throws a code, and i cant pass echeck with a engine light on..... any suggestions?
Move to Columbus. No E-check. lol You should be able to tune the code out of the ECU. I havent done it but have heard you are able to. Call up Slowmotion. Im sure they can set you up.
