In-car videos
Discussion in 'Members' Lounge' started by pissedoffsol, Dec 25, 2002.
  1. pissedoffsol
  2. electric-boost
    electric-boost Member
    cincinnati
    thats pretty fucking sweet dude, we need to make a folder for videos only that would be tight as hell
  3. D See 2
    D See 2 Senior Member
    Baltimore, MD
    that bitch seems like it can haul... whats its 1/4 mile time?
  4. sisteve
    sisteve Guest
    whose car is it? if its his, im going to take his name down, as the second vid shows him going well over the speedlimit, and well, i dont want him to get in trouble...
    so whose car?
  5. pissedoffsol
    uhh read the title.
    its jeffie7's car..
    the 2nd vid, was a 3rd gear drop... he was doing about 65 he said when he dropped it to 3rd. pulled to 130 pretty damn quick it you ask me :)
    fmax kit, darton sleeves, cooler, stuff... i dont know whate else... basically, a modded f-max kit
  6. xlfusionxl
    xlfusionxl Senior Member
    somewhere in florida
    holy shit.
    he owns. hook us up with more vids you greedy bastard.
  7. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    I was using my brothers digi cam =) turned out pretty well for a simple digi cam setup
    btw I was running .75 bar = 11.3PSI I only have 440cc injectors and I have the timing cut back TONS on the top end so just think about what it would be like with some 720s at 16PSI without the timing taken out... =)
    as you can see with the timing taken out the HP almost peeks at 4K with more fuel at the same boost level it should put down 300-320WHP the torque would stay around the same area
    Strut Tower Brace
    Lowered 2 1/4 inches
    Progress Camber Kit
    Aftermarket Struts
    Konig Wheels with Kumho Tires
    3 Auto Meter Gauge Pods on the left piller
    3 2 5/8" Gauges Tach, Boost, Oil Pressure
    MSD 6A Ignition Amplifier
    MSD Blaster SS Coil
    Apex-I Turbo Timer
    Apex-I AVC-R
    Upgraded Motor Mount Inserts
    Upgraded SI Radiator
    MSD Plug Wires
    88-91 JDM B16A
    91 Integra LS Trans
    Full custom 3" from turbo back with 3" tip
    3"" downpipe
    ACT Street/Racing Clutch 6 puck disk
    Hondata ECU with boost upgrade
    4 440CC RC Injectors
    Spearco Intercooler
    T3/T4 Turbo
    HKS Blow Off Valve
    Tial WasteGate
    Open Dump Tube
    Crower Titanium Retainers
    Crower Dual Valve Springs
    ARP Head Studs
    JE Custom Type R Pistons 20 over
    JE Piston Rings
    Eagle Connecting Rods
    Darton Ductile Iron Sleeves
    Pro Drive Oil Pump Gears
    GSR Oil Pump/Housing
    STOCK B16 Headgasket
    1/4 mile time.... pulling it from my butt Im guessing as my car is now + a set of slicks it should run low 12s with out slicks mid 13s maybe low 13s but thats just a guess nothing more
  8. xlfusionxl
    Holla!
    Bro, more videos please. :)
  9. micah
    micah Senior Member
    panama city beach, florida
    ive got a crapload of home racing vids from inside and outside of cars, but ive never loaded any on my comp, ill look into it when i get home
  10. cxjon
    cxjon Senior Member
    man+k+toe
    you car is cool dude !!!
  11. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i've got some from inside the sol if anyone wants to host em
  12. Prowler
    Prowler Super Moderator
    B MT
    I will on HAG. Send me the files on AIM sometime.
  13. xlfusionxl
  14. D See 2
    Baltimore, MD
    yea, post some links y0 ICV's are tight...
