In Effin Sane
Discussion in 'HYBRID -> EG-EK / DC' started by jawdropr, Mar 30, 2003.
  1. jawdropr
    jawdropr Banned
    queens
    i need a new motor because i just bought my car and the head gasket went....yay....reason for a new motor.....i want to put a motor in. i want a motor that is can easily handle a trubo and run in the 12s or 13s :D i need to know what kinda motor i should get as of now then the turbo later i have a 1993 honda civic hatch
  2. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    dude you should put a mazda 13b in there. twin turbo rotarys rule.
    do a search.
  3. jawdropr
    jawdropr Banned
    queens
    can i put a mazda motor in there i was thinking either an b18 or the 2.2 prelude type s motor
  4. BodyDroppedNikes
    caught in a mosh...
    i suggest the B18b from an Integra LS.
  5. jawdropr
    jawdropr Banned
    queens
    whats so good about the b18b
  6. ByTheMoment13
    ByTheMoment13 Member
    Tampa Bay
    b18b - Broad power band, doesnt have to be kept at 8000 to feel the kick from vtec, DOHC, 140 base hp, great torque, and great for turbo, there's plenty of advatanges. and it matches you cars OBD (atleast a 94 and 95) so it'll be a simply swap. just get the B-series mount kit and shift linkage from hasport.
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    It is cheaper to boost than the B16 or 18C,other than that the GSR ownz it.
  8. 98integrals
    98integrals Senior Member
    Kzoo
    umm... no
    the c1 lacks ALL lowe end power with peak torque at like 5-6000 rpm. PLUS the b18b has a slightly larger displacement. Not to mention its way cheaper than a C1, the LS tranny is better for boost (imo cause of longer gears) etc etc.
  9. xj0hnx
    C.C.TX.
    Yea ok chief.I guess that is why they put them in the higher performance models,but hey,what do they know hahahaha.
  10. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    b18b doesn't have vtec...and yes it has better low end torque but who really cares about low end torque if your gonna boost?
  11. sportlinecrx
    sportlinecrx Banned
    B18c's own! B18b has NO VTEC. you can put a B16 head on it, which might be a way to go but i beleive the internals on the 18C's are stronger. the 18C's are standard on Type R's. The 18B is from the integra LS.
  12. saturn_boy96
    Sheridan, WY
    there are more differences btween the c1 and c5, like pistons and their heads are completely different. however the differences between the c and b motors are even more drastic, the b has shorter conrods and lower comp, the c1 and c5 both have oil squirters and built in crank girdles for high rpm stability, but the b motor has a litlle higher displacement. a b18b with a b16 head is called "the poor mans type-r", but really it isn't, the gsr blocks and type-r blocks are built more for n/a tune ability. and i'm gonna leave it at that cause i don't wanna start a vtec war.
  13. Dan 91T
    Dan 91T Junior Member
    Yeah, there's no need to start a vtec vs non vtec war right now... (plus im not even the right guy to do it) I just wanna say that my roommate has a LS (B18B) and he is NOT boosting and he runs with type R's and kills GSR's w/ bolt ons. The reason is the broad powerband and the torque. I'm sure I'm not bringing up new points but I'll just state for the record that GSR's have only 1 more lb ft of torque at a 1000 rpm higher, as well as only having about 3 tenths of a second in the quarter mile on the LS and the LS has one more shift than the GSR at that speed.
    That said there are obvious advantages of vtec to take advantage of small displacement, however, cams and such for a vtec motor cost approxamatly twice what they do for a non vtec motor. Furthermore, the engine itself is cheaper (by a whole lot) and with the money you save you can actually put bolt ons (I/H/E) and cams in the motor (I recommend crower 403's) and have basically the same setup as my room mate (Although he is now doing a clutch and flywheel as well as possibly a final drive) He ran a 15.6 on his setup BEFORE tuning the cams and S-AFC (he was off a tooth on the crank retarding timing 10 DEGREES), before exhaust and before header. He has yet to go to the track with his current set up, or retune on the dyno after adding some other mods, but you get the idea.
    The downside? To run much faster than currently (somewhere in the mid to high 14's) he is looking at resleeving the block and boring it to 2.1L, which involves new rods, pistons, etc. $$$ He hasn't yet decided if he's going to do it. I guess what I'm saying is, budgetwise the LS makes alot of sense, especially when you can pick up the long block for like 800 bucks :D :D or the full motor w/ tranny for about half the cost of the B18C1. The B18C5 of course has its own advantages that place it far above the B18C1 but we'll leave those for someone else to answer (or till later at least, I'm tired of typing ;)
    Dan
  14. White98LS
    White98LS Junior Member
    I'm Dan91T's roommate. If I were to boost a motor, I'd go LS hands down. With an unlimited budget maybe the GS-R would make a little bit more power, but in the real world with real money, the LS wins big time. You can pick up a great LS full swap with tranny for a grand, the cheaper B18C1's are $3k and C5's are $4.5k.... And then if you blow the motor boosting, you pay that premium again. Basically everything for the GS-R is more expensive - trannies, used parts, cams, etc. And if you break stuff, even more money down the hole. The LS makes comparable, if not more power boosted than a GS-R - why would you spend an extra couple thousand for some gain over the LS that may or may not be realized?
    If you wanna talk all motor, it's all about what you want to do with the motor. Drag? GS-R simply because it has great high-end, which is all you really use in drag. Daily driver and autocross? These are both what I want from my car, and in that respect for the money, honestly it beats the shit outta the GS-R. I have spent about $2k on my motor, but the price differential between an LS and GS-R swap is at least that much. I can beat my friend's GS-R with i/h/c/e until 3rd gear (LS 3rd sucks balls) over and over again. I have about 125-130wtq at only 4300rpm, a stock GS-R will only have about 105-108 at 6000rpm, even with i/h/e it will end up with probably 112-118wtq at a similar, if not higher, rpm. My friend's GS-R has slightly better top end than mine but loses until 60mph because of my full powerband. And don't even talk about autocross - his midrange feels gutless compared to mine, mine would obliterate his car on the autocross circuit. I'm not saying my LS is flat-out better than a GS-R, but for certain applications there are advantages, especially when the cash is considered.... All depends on what you wanna do, and of course "how fast you wanna spend".
  15. saturn_boy96
    Sheridan, WY
    i think another thing to consider though, especially with autocross is the transmission. a tranny can keep you in boost and on vtec. and no matter what, the gsr or the b16 tranny will do that better because of the closer gearing.
  16. Roro
    Roro Member
    If you want turbo... B20. Sleeved. PnP the head. GSR tranny w/ Quaife and go to fucking town.
    and just for fun.. THERE IS NO REPLACEMENT FOR DISPLACEMENT :fuckyou2: :ufucktard:
