increase brake pressure
Discussion in 'HYBRID -> EG-EK / DC' started by obetosaio, Jan 6, 2004.
  1. obetosaio
    obetosaio Junior Member
    north eh
    Hey guys i'm running 95 civic with rotors and cali, using stock cylinder. Now i need more pressure would any of you know which on i could swap and from what car looikg for a bolt on solution 15/16th or 1". Also in the future would like to do a is add rear brakes
    :worthy: Thanks ahead of time :worthy:
  2. E_SolSi
    GSR master cyl and booster
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    91 EX
    94-97 Del Sol vtec<--must have matching booster, same with the GSR
    94+ Integra RS
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    is the GSR master the same size as the ITR??, always heard of peeps using the itr unit, just checking and hopefully it will add to the topic.
  5. StyleTEG
    StyleTEG Senior Member
    brake pressure is
    pressure in lbs applied to the pedal * pedal ratio / area of master cylinder size
  6. xj0hnx
    C.C.TX.
    I wanna say the 96-97 or 98s (ITR's) have 15/16's also, but the 99+ have 1".
  7. JDMilan
    Boca Raton, FL
    ok, too bad i don't have a hond anymore..:)
  8. solblu
    solblu Senior Member
    Ricer
    Chepest would be the 7/8 MC from a 92-95 Civic EX it works with the 13/16 booster. If you already have that get SS lines and a 15/16 & booster from a 90 prelude or get your line reflared for the 1 inch MC & booster.
  9. obetosaio
    north eh
    :ph34r: Thanks Guys! :ph34r:
    just making sure these are all bolt on LOL
    and thanks to :worthy: 92b16vx :worthy: for greaat detail
