info
Discussion in 'HYBRID -> ED-EF / DA' started by dirtyrice91, Nov 29, 2009.
  1. dirtyrice91
    dirtyrice91 New Member
    middle of nowhere, ks
    can someone please give me a link to what i need to swap a b18a1 into a 91 civic hatch with the 2 injector setup thanx in advance for your help
  2. dirtyrice91
    i have the complete integra to take parts off of
  3. SlushboxTeggy
    New Jersey
    Use the search and Google. The information is out there for you to find.
  4. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    um...I don't think you can do it with the dpfi
  5. SlushboxTeggy
    New Jersey
    The DPFI is associated with the D-series manifold. He's going to have to convert it anyway because that mainfold won't fit on the B18.
  6. Bobby17772
    Enfield, CT
    thats what I'm saying, unless he had a custom manifold witch would cost an arm and a leg
  7. eatrice
    eatrice New Member
    London, Ontario
    You convert to mpfi, you don't keep dpfi.
    Not a hard concept.
  8. dirtyrice91
    thats what i was planning but im obviously not searchin for the right thing anywhere cause i just want a list of what i need to use off of the teg and what i need to buy but i cant find one i know theres stuff on this swap cause its so common but im not finding it
  9. Bobby17772
    Enfield, CT
    there's a guy on here called monotech I think..something along those lines, he makes the harness you need and they are pretty cheap, but you would need that harness and new motor mounts but besides that you would use pretty much the whole engine bay
  10. efhondakid
    Akron-Canton, Ohio
    Search for dual-point to multi-point conversion, then search B-series swap into EF. Not that tricky of a swap at all.
  11. Bobby17772
    Enfield, CT
    yeah you can do the wiring yourself, it's not really hard, I wouldn't because I don't trust myself with wires but that's just me
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    pretty common..just check out the tech articles on the site..
  13. 78civic
    78civic Junior Member
    NW MS, Y'all
