ok so i have no voltage @ my injectors.
key out, if i (1) take out the main relay and then
(2) unplug an injector connector then
(3) test the wires for ohms from the connector to body ground
i should get a reading of open loop for both wires correct?
im getting open loop for the ecu signal wire but 20.8 Kohms for the injector power wire...
can anybody go through the steps listed and let me know thier results? its a pretty quick test.
i am really thinking my injector circ is shorting out but i dont want to be tearing apart my wire harness if that reading is normal.... im really hoping this is my problem...
thanks
thanks
