Injector plug in
Discussion in 'HYBRID -> EG-EK / DC' started by dustinp, Sep 15, 2009.
  1. dustinp
    dustinp New Member
    kentucky
    i am about to swap a obd1 b18b into my obd2 98 ex with d16y8..i plan on using my stock harness with boomslang obd2a to obd1 conversion..i noticed one problem so far.. the injector clips that plngs into the injector sensors on my y8 harness are differnt than the one of the b18..what should i do just cut them off and wire the obd1 sensor clip onto my y8 obd2a harness or is there an easier route than that..also are there any other problems lik this with other sensors i am unaware of if so please tell me...any input could help..thanks
  2. Briansol
    Yup, cut and paste is the way to do it as you mention.
    You will likely have to do the same thing for the altenator and distributor as well.
