Putting a b18c1 in a 92 hatch. A new engine thats not been run yet. The injectors (Guy told me they were aftermarket) that are on it had notchs that would not line up with my harness. Filed the notchs off so they would fit but now it floods when I try to crank it. The spark appears weak. Can't tell which it is because gas and fire should burn. Any easy way to test spark other than the jump off a screwdriver test? I put a engine in a crx that done the same thing and it was the dizzy but this one was running when taken off. Any thoughts ????
