injector question
necessaryevil
ok so im going from dpfi to mpfi with a p28, would it be possable to run obd2a injectors and not have to use the resistor box?
I was referring to Civic and Integras but yeah, the F/H family is more complicated. My OBD1 Accord has a resistor box too.
so if i have a p28 and run the wires from the ecu to obd2 injectors and then ground out the other side of them i should be good right?
No, you do not ground out the other side. The ECU controls the injectors by grounding them out; the other wires(usually yellow with black stripe), goes to a 12v switched power source.
But, yes, you just wire the (Civic or Integra) OBD2 injectors directly with no resistor box.
