O oldschoolcivic Junior Member Aug 1, 2004 #1 converting a 89 lx to b16 sir. Im stuck on the wiring right now. Where does the 5th wire on the injector resistor box go.
Jeef NO MA'AM Moderator VIP Aug 2, 2004 #3 The yellow and black wires off of your old fuel injectors. Just solder them all together. You should read the dpfi-mpfi swap guides.
D dragon2003 Senior Member Aug 2, 2004 #4 yeah if you any help with the wiring check out this site, it should show you how to do the dpfi-mpfi swap. www.fourthgenhatch.com
