I have 97 dx hb with a b16. Would pluging up the injectors in the incorrect sequence cause the car to fold the spark plugs.
Yea I dont see how you could mess up the plugs unless you took all the sheething off the injector harness. If you hooked them up wrong the car probably wouldnt run at all, but since I have never done this im not sure. Could you post a pic of your spark plugs numbered with the cylinder they came out of. Seeing the plugs makes diag much easier. You might just be running excessivly rich, which would definatly foul the plugs.
also if they are hooked up wrong if it did start it would definatly backfire and detonate like a MOFO.
