INJECTORS D-series question
Stupid Question
off a 1991 CRX D16a6
Anyone know why cut off injector plug-ins from a D series DOHC would not plug into a D series SOHC injector??
I bought an engine from a guy and he threw on some fuel rail from a??? which did not fit even close so I found a rail and cut off fuel injector plug wiring off of a DOHC (plugs for the DX to SI convers.), but now the new plugs won't plug into the injectors I have on the engine.
So I am not sure if I have the wrong injectors (if the guy just threw on some off of a pile he had or what), or are these plugs I got wrong.
Can't find anything on the net on plug differences, so i was hoping one of you guys might know something.
Any input is greatly appreciated.
Thanks! :spin:
plugs are different according to what obd system the injectors are from, not dohc vs sohc your rex is obd0 (unless converted) and he probably gave you obd 1 or 2 injetors
Ok, but if I want to use these obd 1 plugs to do my dx to si wiring on my crx can I just find a pair of obd 1 injectors and use them? or is that going to screw something else up??
Rest of car will be obd0
No you need obd 0 injectors because they are a low inpedance injector
the ones you have are high impedance so no.
i just picked up 4 obd0 injectors from a teg d16a6 for 26 bucks so if you need another pair i'll send them to you for 50 shipped comming from so cal.
Tegs diden't come with d16a6's they came with d16a1's but the injectors are the same
Thanks for the information. Anyone have a picture of an obd0 injector plug-in configuration, or can anyone snap one quick?? So I make sure it is the injectors that are wrong and not these stupid plugs. I am doing the DX to SI conversion so you know.
All of the injectors that I have seen for sale look the same on the outside, where the real visible difference is in the plug-in design.
IF you can snap a picture I would really appreciate it. If you want put it on here or send it to me at,
justinpoenitsch@hotmail.com
Thanks alot! ;)
