Injectors question?
Discussion in 'Engine Building' started by ovcrash, Jul 4, 2003.
  1. ovcrash
    ovcrash Senior Member
    Quebec, Canada
    What type of injectors are on a Prelude 97? Peak and Hold Injectors? or Saturated Injectors?
    And is it hard to change? or does it cost alot? And what else do i have to change, while changing the injectors?
  2. se93
    se93 Junior Member
    1997+ H22A injectors are Saturated. To convert to peak and hold injectors you will need to add a resistor box. Check out the following page on the hondata website for complete details.
    http://www.hondata.com/techinjectorwiring.html
    Hope that helps.
    Regards,
    Mark
  3. ovcrash
    Quebec, Canada
    i mean, is the injectors hard to change? not change the type of injectors..but the injectors i already have.
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    they are easy to replace. just relieve the fuel pressure, unbolt the fuel rail and do it up..
