Yes they fit. You might have to swap connectors and/or use your stock injector o-rings. You just need to run a resistor box with them(or just solder in 10-ohm resistors on the positive wires to the injectors).
Only reason to upgrade to those is if you go turbo. Otherwise, they're a waste.
definately not the way to go. Stick to the 240cc stock injectors and specially for daily driven whip!
Get a fuel pressure regulator and 255 Lph Walbro fuel pump if looking for better response no need to change the injectors unless you plan on going turbo or SC.
