great, i just got my injectors for my built gsr turbo motor. Brand spanking new Rc 550s. Problem - I got peak and hold injectors and need Saturated. didnt even think to check. Isnt this fun? Any ideas??
actually it isnt that bad...alls you have to do is wire in a injector resistor pack from an 0bd-0 car. or....send the injectors back and get saturated, but most people convert over to peak and hold...
Here are the prices for RC injectors... http://www.rceng.com/prices.htm Your honda uses saturated injectors so if you have peak and hold injectors you will need to install a resistor box. I don't think it really matters too much if you use peak and hold or saturated. Hondata/Uberdata shouldn't have any troubles idling 750cc injectors. I have a buddy that has used hondata and uberdata on his car and he was able to run like 880cc or something like that just fine.
i run 880s with uberdata just fine. if you can... get the high impedence injectors. they are much better that rigging in resistors. as of now, rc makes a 750 high impedence... and that is the largest one made. i woudn't try to run 550s at 400 hp though.
Originally posted by GSRTURBO@May 19 2004, 05:57 PM so basically if i use saturated injectors, i dont need a resistor box. If i use peak and hold injectors, i need a resistor box. Correct?
i'm using 550's peak hold with radio shack 10ohm resistors wired inline. hondata.com has a diagram on how to wire in your resistors if you need to do so.
