EF9_boy
i bought innovative mounts to swap a b20z into my ef the rear mount and trans mount are fine but im having issues with my driver side mount.
on my b20 there are 2 threaded posts that are tapered at the bottom that my mount slides over
the problem is my mount wont go over the tapered section so it wont sit flush and only 1 nut can be screwed on
also when the mount is on the posts it sits at a serious angle...is this normal?
(i remember some guy on here had the same angle issue i but couldnt find the thread)
do i need to drill out the holes on my mount to make it slide over the tapered section?
