Innovative traction bar bushing help
Discussion in 'Wheels / Suspension / Tires / Brakes' started by HATCHET_HONDA, Jan 17, 2009.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    anyone know how the bushing kit is installed into the innovative traction bar on an ef? im confused on where the big washer goes in between the bushings
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    is this the replacement crossmember or the full aftermarket one?
    Also, if it's the aftermarket one, I had the big washer in my Avid kit too....never knew where it went and they never told me(just said they would send me new instructions...which didn't say anything about the washer).
  3. HATCHET_HONDA
    hobart, indiana
    its the replacement crossmember and uses the oem radius rods. i bought the bushing kit and it came with 4 bushings and 2 big washers. i havent a clue what position those 2 washers go in. does it really matter u think? maybe as long as i put both in the same spot on each side
  4. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    They should go outside the bushings so it compresses them.
  5. HATCHET_HONDA
    hobart, indiana
    but theres only 2 of these washers.....i have them on the side towards the tire. it goes
    factory washer-innovative washer-bushing
    and how tight should the nuts be on the torsion bars?
  6. 91_civic_si
    Wasilla, Alaska
    2 washers and two bushings. The washers are on the outside. If you look at each hole you will only see the washers when installed correctly. The tightness depends on where you want the wheels to sit as this is for adjusting when aligning the car.
  7. K2e2vin
    Raleigh, NC
    OEM radius rods can't be adjusted. They use a spacer where the bushing is so it's either torqued down, or it's not. IIRC, only way to adjust OE radius arms is with an aftermarket spherical bushing like the SBMS unit.
    I'd say, just use the OE washers. What confuses me is my Avid kit has those large washers too; and it's an aftermarket unit with no large rubber/poly bushing.
  8. get_nick
    Washington State
  9. HATCHET_HONDA
    hobart, indiana
    yea thats how i have it. factory washer/innovative washer/bushing/crossmember/bushingfactory washer/nut
    i was gonna just leave those washers out but theres alot of play without them included
