Installing A/F & Oil Pressure.
Discussion in 'General Tech and Maintenance' started by JDMPlaya, Sep 26, 2004.
  1. JDMPlaya
    JDMPlaya Senior Member
    Columbus, OH
    Is there an easy way of just telling me where I need to hook my a/f up to & same with the oil, The instructions sucks!
  2. pissedoffsol
    oil pressure- tap off the oil pressure sender.
    a/f don't even bother unless you have a wideband o2.
  3. JDMPlaya
    Columbus, OH
    What would be the best way to "tap" my oil pressure sender..
    I'm just wondering what would the A/F go into?
  4. pissedoffsol
    a/f taps off the o2 signal wire.. i beleive its the green- but don't quote me.
    the oil pressure sendor, you're going to need the 1/8" BSPT tap into the back of the block just like you would for running a turbo oil feed.. and then all those conenctors, and finally a T, 1 for the pressure gauge, 1 for the oil feed
  5. JDMPlaya
    Columbus, OH
    Thanks for the help!
  6. 97CTR
    97CTR Senior Member
    I'm pretty sure that the O2 signal wire is white, blacks are heater ground, 12v power and the green is O2 signal ground.
    Thats how I just hooked up my plx air fuel gauge and its working great with the hondata. :)
    go tooil pressure gauge and go to the articles section, it will be under the how to, for oil pressure pickup
