For some reason the lithium grease that you're supposed to use was not in the box! Is it important to use lithium grease, or can I use motor oil instead? Suggestions.
Also, the instructions say to install the rubber washers differently depending on if you want a race car feel, or not. The difference is just installing two rubber washers on the drivers side of the shifter and one on the passengers side, or the other way around. So...which way should I install them. LoL Sounds silly to me
