installing cda-5755g
mnjh94
Member
I put a alpine tda7563 with cd addon cda5755g, amp subs and 4 speakers. before i installed the cd addon, tape and radio works fine, but when i pluged in cd addon, the radio/tape output volume does not work, but when i put cd in a cd addon, volume works fine. what did i do wrong?
well, the only thing i can think of (if i understand your language) is that your car possibly has a factory amp and you have the power antenna wire hooked up to the remote turn on lead for the factory amp. that could explain no sound on cd situation and possibly the volume thing but probably not. i need info on vehicle and what a "cdf39t64udk" is to help out more.
-Liquin
its an alpine tda7563 . that is the model number of his alpine headunit.
the cda5755g is the changer that is controlled by the headunit.
IE: my mirage and colt share my alpine cda7894 cd/mp3/reciever.
