I am going to install a front sway bar from a 94 ex onto my 93 dx. I have the bar, bushings, end links, and U brackets. I have been looking at some diys about how to do this, but the ones I find are usually about installing an aftermarket bar onto a model that already has a stock front bar. Do I need anything other than what I listed above? Are the bolts that hold the U brackets already on the car, or will I need to get some? I also read in one of the threads that I found, that a spacer was used between the U bracket and the body, is that correct? I just need to know what else I need before I begin because I cant afford to get half way finished and then realize that I dont have a part. Thanx for any help.
