Installing The "bitch Pin" (shift Linkage At Trann
Discussion in 'HYBRID -> EG-EK / DC' started by Hybrid93Hatch, Apr 10, 2003.
  1. Hybrid93Hatch
    Hybrid93Hatch Member
    I went to install the shift linkage today on my Eg / GSR hybrid and the damn thing is about half-way in. I used the old pin I took out the Cx since it looked exactly like the new GSR one I bought and was NOT mushroomed from when I beat it out with the socket extension.
    Anyhow, it's a little f**ked (mushroomed) from where I tried to beat it in. I'm probably going to remove it in the morning and if you guys have any tips install the new pin afterwards.
    It was a "bitch" getting it out, but getting it back in seems to be a "whore"
    I'm just hoping someone has done this enough times and maybe has a trick you can share
    Thanks!
    PS <> Will I ever have to remove this thing? Yeah, I'm sure if I blow the motor or the tranny gets ruined I'll have to remove the shift linkage. But, I've read where people have pulled the motor with the shift linkage attached. Should I just beat the damn thing in if worst comes to worst?
  2. E_SolSi
    find a bolt laying around that is a little bigger than the pin (flat end not tapered)
    tap the end of the pin in with a hammer (just so it stays)
    put the bolt up against the pin and smack it in with the hammer
    thats what worked for me .... good luck :)
  3. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Put the pin in a freezer overnight. When you install it, make sure the pin is COLD COLD COLD and it will be contracted enough to tap in easily.
    This worked for me. Otherwise, I just beat the living shinola out of it, and never had a problem after my shoulder quit hurting ;)
  4. no2psi
    no2psi Senior Member
    Use a bolt from the a/c compressor. It has a tapered end and fits into the pin just right. Like it was made to remove and install that pin.
  5. you should of tapped it in, not pound it out.
  6. EGLSHB
    EGLSHB Senior Member
    i use a 1/4" rolled-pin punch... is has a little nipple on the end that centers itself in the pin, and it really makes things easier
  7. huu
    huu Junior Member
    i used the 14mm bolt that holds together your exhaust to punch it out. its the bolt on the exhaust that has a spring on it. its the perfect size for the pin. as far as getting it in, wd40 worked pretty good.
  8. Teambypass
    Teambypass Senior Member
    The pin is easy to take out. go to SEAR and purchase yourself a punch which cause around $4.94 and that should do it.
