Insterment Cluster Problem
Discussion in 'ECU's, Electronics, and Tuning' started by dwn2low, Mar 8, 2003.
  1. dwn2low
    dwn2low Senior Member
    Little Rock AR
    I just put in Indigo faces in my Civic 92 HB. They look nice and work well but all my gauges are off. I put then back on they way they came off. What i did then was plug it in and set all the gages to 0 except my Gas. However my speedometer doesn't work now it jumps up to like 20 -40 and stayes there. I did notice that the gauge faces did not have a needle to stop my pointer from going backwards could this be part of the problem? I'm lost someone help?
    Thank
    Mark
  2. sirkurtius
    sirkurtius Member
    toronto canada
    did you take the needlles off when u put the gauges on?
    are your needles painted?
    the gauges are very sensitive and when u put on the new face's u should not
    touch the needles as much as possible or take them off
    if u want to change the color of your needles then use a felt tip marker and not
    paint, as the weight of the paint will throw off the reading
    as for your problem right now, u might have really screw the gauges up, so u might
    have to find a cluster at the reckers
  3. dwn2low
    Little Rock AR
    I had to take the needles off to put the faces on. I tried to put them back at 0 all of them work correct now except for my spedo. It still jumps to 20-40 then stayes there.
    Thanks
    Ohhh I did not paint the needles
  4. sirkurtius
    sirkurtius Member
    toronto canada
    u should have left the needles on and worked the gauge faces inner cut out hole around the needle, but don't feel bad you r not the first person to do this
    any way u say there is no small needle to stop the speedo fron dropping, did u remove it or did the cluster not have one?
    if it did and u removed it then try this trick
    1. take off the needle [carefully]
    2.start the car and let idle
    3 put the needle on at 0mph [carefully]
    4 test drive car
    tell me if this works
  5. dwn2low
    Little Rock AR
    Ok,
    I'm going to try that first ting tom.
    Mark
  6. dwn2low
    Little Rock AR
    I figured it out. I pushed the needle down 2 far and it was sticking on the gauge face. The otheres were just off by 1/4" so I moved them. I did this by filling up on gas and placing that one at the top, and when my engine was cold i placed the temp one. Thanks
  7. sirkurtius
    sirkurtius Member
    toronto canada
    sounds like you found the problem yourself but if i helped you look in the right direction then you are welcome.
