intake and exhaust valve?
Discussion in 'HYBRID -> EG-EK / DC' started by GoodSleeperRight, Nov 18, 2004.
Thread Status:
Not open for further replies.
  1. GoodSleeperRight
    GoodSleeperRight Member
    New York
    I am going to do a b16a (sir 2) swap this winter and i wanted to build the internals...I wanted to keep it mostly honda OEM parts tho.So my question is can i put only an ITR intake vavles on it and be ok without the exhaust?
    This is the setup i want to use is...CTR cams,The port flow racing vavle kit,It has the inner and outer springs with titanuim ratainers.
    And also what stock honda pistons OR aftermarket with stock bore will work good with this setup.I am going all motor
  2. GoodSleeperRight
    New York
    Someone has to know :(
  3. rcoolb2002
    rcoolb2002 Member
    Maryland
    Honestly i would just get a valve job on your stock valves. If a competent machine shop does the work, you should get a positive flow increase. Much more than you would just by putting intake ITR valves.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    This topic has been closed :locked2:
    Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth.
    If you have any questions, please PM the moderator who closed this topic.
    -The moderating Team
Thread Status:
