intake manifold Q
E.N.G
on a zc engine swap can i use the stock intake manifold off a 89 crx dpfi
yes definitly but it doesnt gettin any better do mpfi swap it will works much better than DPFI since DPFI has 2 injectors and MPFI has 4 injectors :thumbsup:
thanks the only problem i have with that is i don't know what i need to do the swap from dpfi to mpfi, if you can help me with that that would be great
if you check the swap articles and gen tech articles here you will find just about anything you need
