intake manifold
CRX2NR18
i know the Y8 intake mani will fit on my z6 mini me (wired OBD0) but will all the connections and everything still wire up the right way? any rewiring? or is everything the same, i heard moving from the a6 intake mani to the Y8 is proven like 3 or 4 HP, which in my case i need everybit...
thanks
Tj
All you are doing is gaining a little bit more room in the intake chambers. You are going to have to pull off all of your sensors from the z6 and put it on the y8.
I pulled a Y8 out of my buddies civic to drop a b16a2 in, so I have his engine in my garage. I compared it to my z6 and everthing almost looks the same. I would just swap out the throttle body and everything else should be ok.
Its basically just a bigger manifold, I don't even think you are going to get 3-4 horse out of it, but it's your call.
