Intake Manifold
lswhitecivic
VIP
I am about to buy a new intake manifold for my b18b. I was looking at skunk2, is there any other brands i should look at? Also is the manifold a simple bolt on or is there some other stuff that has to be done at the same time?
Ben
the skunk2 comes bare, as is the case with most aftermarket IM's
you'll have to run all the vacuum lines, install the sensors from your old IM
depending on the mods there are other brand you could look at, but for a stock, or mostly stock motor, skunk2 is one of the best choices out there
jg intake manies are to big for n/a more for f/i from what i hear
skunk 2 is like a type r mani with a slightly larger bore isnt it ?
I would run the AEBS manifold then. The JG isn't necessarilly for FI but it does work better on a high reving motor. I think the AEBS/Profesional Products manifold is much better than ther skunk 2 for 1/2 the price though...
[post=418204]Quoted post[/post]​
Hey dummy AEBS does not make an intake manifold for a B18B1 or for a B18C1 for that matter. They only have them for B16 and the B18C5.
Originally posted by integraslut78+Nov 17 2004, 01:05 PM-->
sohcslammer
[post=418236]Quoted post[/post]​
My bad. :p Actually they just came out with one for the GSR but still no B18a/b. I guess go with the skunk 2... :shrug2:
Hey B would you recommend the Skunk2 for under 215hp.
Not trying to thread jack just trying to see what he would recommend.
Hey dummy, the B18A/B is the same flange as the ITR/B16. :p
For a B18A, I would go with a used ITR manifold. Cheap and flows great.
Originally posted by nfn15037+Nov 17 2004, 01:46 PM-->
integraslut78
[post=418358]Quoted post[/post]​
I was told by AEBS that they did not have a IM that would fit a B18B1 Sorry gosh.
I know sohcslammer I grew up with him thats why I called him dummy but I do not know you so you do not have to call me that. Thanks.
Originally posted by integraslut78+Nov 17 2004, 03:53 PM-->
Originally posted by nfn15037@Nov 17 2004, 01:46 PM
integraslut78
[post=418362]Quoted post[/post]​
You don't know me. You only think you do. :ph34r:
I will remember that around your Birthday when is it????? hahahahahahaha
