Intake Manifolds..
Discussion in 'HYBRID -> EG-EK / DC' started by b20_silver, May 18, 2003.
  1. b20_silver
    b20_silver Junior Member
    Palmdale
    My b20b's intake manifold(the so called "giraffe) is of course way to tall for the hood, so Im in the search for one. A few questions if u will:
    this is for a '97 b20
    Can I use an older LS intake manifold?
    Can I reuse some of the sensors off the b20's?
    Will any of the other manifolds(b18c, b16a, etc.) fit on the head?
  2. Havok
    Havok Senior Member
    Florida
    Are you trying to put a complete longblock in? In What car is it going into, and why not use a B16/B18 head with that heead's manifolds?
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Cause that is a lot more work. :)
    The older LS manifold will bolt up, but I am not sure if it will have all the sensors that your OBD2 IM had (I believe it does but can't promise). You should just get the Skunk2 LS IM and move all your sensors over. Unfortunately none of the the VTEC IM's will fit your head without modification, the Skunk2 would be much easier.
  4. sirex
    sirex Junior Member
    I dont know if this helps you guys any but I put a dol sol vtec manifold on my b16a1 in crx and it used all the sensors except the sol manifold didn't have a place for the FIT valve.
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    If he uses a 96-99 it should work fine.
  6. lsvtec
    If he uses the 96-99 manifold there is no worries, but the OBD1 manifolds are a different question.
  7. b20_silver
    Palmdale
    Im keeping the b20b no vtec.
    In other words, VTEC IM's will fit with mods, and stay in 96-98 obdII?
  8. lsvtec
    OBDII will work for sure, I don't know about an older manifold. If you an afford it go Skunk2.
  9. solblu
    solblu Senior Member
    Ricer
    Any of the LS manifolds B18A up will bolt on. You'll just have to put the missing or different sensors from the B20 manifold on an OBD0 or OBD1 manifold. For the $ it's better to just get a Skunk IM and put the B20 sensors on it.
  10. b20_silver
    Palmdale
    I dont have the $$$$ for Skunk2..
    :ph34r:
