intake swap to d16y7
Uppertorso
I wasn't sure if i should have posted this in swaping forums or here, but here i go:
I have an intake for a obd0 crx, and i know it bolts up to my D16y7 engine, but what is transferable. Are the IAC valves the same, will they just plug in?? Can i use the throttle body from my D16y7 on the new intake?? Is the tps (throttle position switch) the same from obd0 - obd1 - obd2??? Can i use injectors from a 92-95 civic and use it on my D16y7???
Any input is appreciated, thanks
AP
use your tb and gasket...use your y7 injectors with the a6 fuel rail...use a6 throttle cable....personally id go with an auto y8 manifold....it would be perfect for you...same 3wire iacv
