Intalling B18c Flywheel
legutki
I just finished resurfacing my flywheel and the manual said to line up the matchmarks. I could not find any marks on the engine or the flywheel. Do you have to line up the flywheel a certain way or can you just bolt it on any way?
thanks
they might meen line up the proper holes with the preasure plate, just bolt the thing on thats all i have ever done
matchmarks
If you look at the engine side of the flywheel and the end of the crack, there are two holes in the crank that leave marks on the backside of the flywheel. Those should match up with each other.
+ 1 ..........they are there you just have to look real good
