integra b series parts
Discussion in 'Parts: For Sale/Trade/Wanted' started by civicblue1993, Feb 17, 2009.
  1. civicblue1993
    civicblue1993 New Member
    ok there are a few things im looking for to complete my swap let me know what you have and a price thanks in advance
    NEEDS
    b series short throw shifter
    b series (93) msd setup (cap, rotor, blaster 2)
    b series aftermarket pulleys (p/s, alternator, crank) need to fit 90-93 ls
    b series aftermarket fuel rail
    92 civic LX front slotted or drilled rotors(would prefer new if you have some laying around
    92 civic LX energy poly bushing kit
    let me know if you guys have any b series performance parts laying around.
    BOUGHT thanks fellow hondaswap members
    b series dc header BOUGHT
    94-01 axles and mid-shaft BOUGHT
    b series starter BOUGHT
    b series fuel regulator BOUGHT
    b series AEM cam gears BOUGHT
    b series clutchmaster stage 3 clutch BOUGHT
    99-00 civic si radiator BOUGHT
    b16a2 trans BOUGHT
    94-01 integra shift linkage BOUGHT
    94-01 integra billet motor mounts BOUGHT
    obd 1 integra ecu BOUGHT
    b series power steering pump BOUGHT
    b series alternator BOUGHT
    obd1 distributor BOUGHT
    obd1 injectors BOUGHT
    map sensor setup BOUGHT
    THANKS AGAIN TO ALL YOU GUYS WITH THE GREAT PARTS AND GREAT PRICES!!!!
  2. civicblue1993
    any one have anything for me
  3. efhondakid
    Akron-Canton, Ohio
    I have a P/S pump with an AEM pulley on it, name your price.
  4. welfare
    welfare Ancient Member
    New York
    Careful with the aftermarket pulleys, some of the older b series crank pulleys used a single V belt for the p/s pump while the newer ones use a 3 rib serpentine style belt.
    Just make sure you get the parts to match :)
  5. welfare
    New York
  6. civicblue1993
    thanks for the heads up LIST UPDATED AGAIN
  7. welfare
    New York
    I see you are looking for brake upgrades. . .
    A better brake upgrade yould be to switch over to integra knuckles and use the integra rotors and calipers, bringing overall front brake diameter up. Easy bolt on upgrade. I know for a fact that 94+ integra will work, 90-93 Might work but Im not 100% sure on that.
    and no you cannot just put the integra rotors and calipers on the civic knuckles because the calipers will not bolt up correctly :)
