i have a few problems i bought a 93 gsr motor tranny for my crx would it be easy to convert the engine to obd0 or the car to obd1 and does hasport sell the conversion harness by the way the engine has about 70,000 miles and bought the whole thing for 600. not bad deal!!
you got a steal on the motor. I'd wonder if it was hot for that price
It would be unquestionably easier to convert the motor to OBD0
It would be unquestionably better to convert the car to OBD1 since OBD1 electronics currently run vtec motors much better.
Good luck. If you decide to convert to OBD0 I have a line on parts.
definitely convert the motor to obd0... all you are going to need is an obd0 distributor and everything else will plug in. you'll need to run an obd0 pr3/pw0 dohc vtec ecu. you'll have to add the vtec wires if its an si, and you'll have to run the vtec and mpfi wires if its a dx.
